Metrolink Wifi
ValleyLines142
25 Jul 2011
Gloucester
Morning all,
I did post this question in the Manchester Metrolink Master thread; however, following the decision by the team to close it and have several threads instead, I have made a new one! A sensible idea I think; there were too many topics being posted into one big thread and no one could see hidden posts such as mine!
Is 3054 still currently the only tram with wifi fitted?
MTIA!
Manchester77
4 Jun 2012
Manchester
Yeah it's still only 3054 as once you've used it they want your fill in a survey about the wifi. I found it quite good was able to check this site and send some messages!
rebmcr
15 Nov 2011
St Neots
I've seen it on East Didsbury - Rochdale a lot. Not sure if it lives there as standard.
Shrimper
14 Apr 2012
It's Queens Road based so can end up on anything (though is less likely on Eccles simply as Eccles/MCUK is mostly the non-VRS M5000s). Stand in Piccadilly Gardens and it will pass you eventually as long as it isn't in the workshop or designated spare!
1e10
13 Jun 2013
Was on this once but didn't realise there was free Wi-Fi until after. You'd think the Wi-Fi SSID would be something a little more obvious..
Moonshot
10 Nov 2013
I was actually on this one today.....great idea, roll it out to the rest of the fleet!!
1e10
13 Jun 2013
I don't understand why the roll-out is so slow. There is clearly demand for this sort of service and companies out there with the technical expertise to roll this sort of thing out at scale.
185
29 Aug 2010
It's an evaluation unit, initially to see if it works. As taxpayers money is initially funding it, the PTE want best value, and try to avoid buying things that simply don't work. The time of the rollout will happen subject to funding and the technology actually working.
1e10
13 Jun 2013
My point is that there are already companies out there providing solutions for buses and trains. We already know this stuff works.
34D
9 Feb 2011
Incidentally, it is dirt cheap. The bus company I work with has had a quote - something like £15 a month with equipment supplied for free.
507 001
3 Dec 2008
Huyton
I know at first the equipment was suspected of causing a few problems with other on boar systems. I have no idea if these problems have been resolved.
That's only slightly more than home wi-fi!
Always a risk of electromagnetic compatibility issues with something like this, though I would have thought the tram would be more likely to affect the wi-fi than the other way round. So a good idea to make sure there are no problems with the initial one before committing to fit 93 more.
rebmcr
15 Nov 2011
St Neots
This is not Satellite- or Mobile-based though, it piggybacks on the mesh network installed for the TMS signalling.
WatcherZero
25 Feb 2010
And also the spare capacity of the fibre optic trunk theyve laid alongside the lines for the new signalling.
