Mark 4 DVT Noise
ryan125hst
2 Jun 2011
Retford
I watched this old video of an East Coast Intercity 225 the other night and noticed the strange sound the DVT produces. I know all the Mark 4 coaches have a static converter (which converts the 1000V AC Electric Train Supply to 400V AC three phase power for use by air conditioning, catering etc) which make a noticeable sound, but the sound from the DVT sounds different as it seems to vary in pitch a lot more than the other coaches. Is there a reason this is the case on the DVT's?
ryan125hst
2 Jun 2011
Retford
I wonder if it is a slightly different static inverter to those used on passenger coaches? Or maybe it's starting to go faulty? I'm sure I've heard it before though that DVT's sound like this so I'd be interested to understand why.
BillStampy
6 Jan 2024
Llanharan
It's probably a similar case to the coaches, TfW's DVTs do it too.
boiledbeans2
15 Oct 2020
I'd like to jump on this thread and ask what's that "tick tick" sound, like a clock? I hear it on many older trains as well.
ryan125hst
2 Jun 2011
Retford
What's the reason for the DVT's requiring a Spirax valve as they don't, to my knowledge, contain an air compressor?
ryan125hst
2 Jun 2011
Retford
Just had a thought - is it anything to do with the E70 brake valve used to ensure the air brakes apply from both ends at the same time?
D365
29 Jun 2012
DVTs have DW3s don’t they?
Good question. I was about to cite traintesting.com, but it appear that this is referring to Class 43 ’DVTs’, as opposed to purpose built Mk3 or Mk4 DVTs:
Once the loco's early teething troubles were overcome during the running with the Mk2 stock, testing was extended to include a 5-car rake of Mk3 sleepers which could be run in push-pull mode with the HST DVT by use of a screened cable running the length of the train. This was most important with respect to the train's braking as the control system released and applied the brake from the 91 and the DVT. Hence when being hauled by the 91 the E70 brake valve in the DVT was held off by the TDM and any break in circuit (or a fault) meant a remote brake application from the DVT.
Previous posts on RailUK seem to state that all DVTs are fitted with DW3, as per Class 90. But my understanding was that the Class 91s are fitted with DW2?
ryan125hst
2 Jun 2011
Retford
I don't know, I've seen E70 mentioned before. Were they only fitted to HST's?
But your quote mentions an E70 valve in the DVT?
D365
29 Jun 2012
Dave wasn’t entirely clear in the writing of his article. The DVT in that instance was actually a buffered Class 43, which is what I had attempted to clarify in my writing.
Class 43 and Class 56 were the two locomotive/vehicle types which were fitted. Also to clarify that my BR training notes name the Davies & Metcalfe E70 as an entire ”brake control system”, not just a singular valve.
DW2, as fitted to Class 91, is the Westinghouse equivalent of the E70. The DW2 and E70 Brake Control Units are purportedly interchangeable.
However it’s the Westinghouse DW3 which is an entirely different system, hence my earlier question whether or not they are fitted to Mk4 DVTs. The Class 90s are the only vehicle I 100% know are fitted with DW3.
s491
6 May 2025
Reading
Don't think that's entirely correct.
AFAIAA, 91's were all D+M brakes and had a version of the E70 which allowed blending of the brakes (rheostatic and air). The Mk4 DVT's were DW3's and Westinghouse brakes.
HST Power cars had a mix of E70 and DW2 - and as far as I know the only UK application of the DW2. 43002-152 were built with E70 brake control unit and 43153-198 built with DW2. As with cooler groups, the brake control units got mixed around with them appearing on power cars across all sectors. However once the re-power project had finished, all the DW2 units were with FGW/GWR. DW2's used to be instantly recognisable back in the day by whistling loudly when the brakes were applied through each brake step. This eventually disappeared when a choke was fitted on the unit exhaust.
whoosh
3 Sep 2008
Some HSTs were fitted with a DW2 brake control unit instead of an E70. They were louder.
ryan125hst
2 Jun 2011
Retford
This is probably why I've never heard of the DW2 or DW3 until now - I guess everyone has just called them E70's.
I didn't realise the HST's had two different types. Was there a reason for this?
Are there any videos of this, or was it only audible inside the power car?
D365
29 Jun 2012
That’s definitely not the case within the rolling stock industry.
As I’m told the E70 and DW2 are functionally compatible, I can only assume dual sourcing. Similar to how the Class 15x classes had a mix of Davies & Metcalfe or Westinghouse brake controllers, but are compatible for multiple working.
43096
23 Nov 2015
BR’s dual sourcing policy, that also gave two types of HST cooler group (Marston and Serck) and two types of HST traction motor (Brush and GEC).
