Manchester Piccadilly
Peter Gl
11 Aug 2007
Eccles, near Manchester
Anybody know what the wires/tracks are for at the rear of Piccadilly station, running parallel to Store Street? I realise Piccadilly is a terminus and that an amount of track is required for the vehicles to reverse, but this length of track is a few hundred yards, far more than is required just to reverse vehicles.
Are they intended to be the start of a new route?
Pete
Class20
2 Aug 2010
Bamber Bridge
I take it you mean Manchester Piccadilly. Then those tracks are the start of the new extension to Droylsden and Ashton-under-Lyne.
Piccadilly station will become a through station for some services while others will continue to terminate there. A central reversing line has been provided just beyond the undercroft.
snail
16 Jun 2011
t'North
If you look more closely you'll find the track extends for almost 6 miles... :lol:
185
29 Aug 2010
Think he means the turnback loop. It is quite lengthy and you can get about four trams in it.
bluenoxid
9 Feb 2008
It is probably for flexibility. If you can imagine that there is something going on in Manchester or towards Eccles, Altrincham or Bury, the ability to launch trams at Man Picc in quick succession will be appreciated. Can the trams be run in 4 tram formations for ECS workings?
185
29 Aug 2010
The middle track is the turnback loop.... the two tracks either side of it will be the running roads for the new East Manchester Line, out to the Etihad Stadium, Droylesden and eventually Ashton. The new line is effectively an extension of the tracks from Piccadilly Gardens to Piccadilly Station, which will soon run right through.
