Man > Cov > Eus > Man
easyken
19 May 2011
Manchester
Sorry for the potentially silly question, but I have a meeting in Coventry on a Tuesday (24th March) and then a meeting in London on Weds AM (25th March).
How would I go about booking a ticket from Manchester Picc -> Coventry -> London Euston, but then back direct London Euston -> Manchester Piccadilly?
This type of journey surely can't be particularly strange - but I can't work out how to do it easily.
All help appreciated - thank you in advance!
Mcr Warrior
8 Jan 2009
Would a £68.60 Off Peak Return from Manchester Stns -> Rugby possibly work? Presume valid via Birmingham International and stopping short at Coventry? If so, then an appropriate separate return ticket for the following day from Coventry to London Euston (what time do you have to be in London for?) Maybe a £99.20 route "LNR + WMR Only" Anytime Return. On the way back, you'd need to be on a West Midlands train that calls at Rugby and change there, noting that a couple of late afternoon Northbound Avanti services aren't 'pick up' at Rugby if travelling onwards to Manchester Piccadilly. Or can anyone suggest a better option?
Vexed
12 Jan 2020
Herts / Hants
Obviously not applicable if you have to book through your work ticket portal, but the forums ticketing site will let you choose different via points on the outward and return. You can also set it as a required change with additional change time for your meeting, though note you aren't officialy allowed to exit the station during your change if you have an Advance ticket. However it may be cheaper to get multiple tickets and not use a portion of one of them, which no ticket site will do. Mcr Warrior has one suggestion above for this.
Are you travelling to London on Tuesday or Wednesday?
30907
Anytime return no problem.
Offpeak Return is OK if you stay overnight in London, and the morning restrictions fit your times.
easyken
19 May 2011
Manchester
Thanks all, appreciated.
To Watershed's point: "If so, in principle you can just use a through return ticket for the whole journey, since Manchester-Coventry-London is a valid route from Manchester to London. "Any permitted" walk-up tickets for this journey allow you to break your journey."
I think I will probably do this.
Is there a good website for a 'layperson' such as myself to find this out without having to demand of your time, for future reference?
walkingsophie
29 Nov 2025
Sunbury
The advanced settings in the forum tickets site make these kinds of things possible to search without too much difficulty
Belperpete
17 Aug 2018
You don't appear to have answered the question about where you are spending the night, in Coventry or London? This is critical to what options are available to you.
With something like an off-peak return, you are typically allowed to break journey on both outward and return journeys. However, the outward journey must be completed the same day, so this type of ticket is not much use for an overnight break of journey. The return part of the ticket can be broken overnight (or even longer), as it has a 30 day validity. Note there are exceptions to this, some tickets do not allow break of journey.
With an any time return, the outward portion usually has a three day validity, so can be used to break journey over night. But these types of ticket can be very expensive.
The options I would have considered for this kind of three legged journey are:
1. Separate return tickets Manchester to Coventry, and Coventry to London
2. One return ticket Manchester to London, and a separate single Coventry to London
3. Separate singles Manchester -Coventry, Coventry - London, London - Manchester
Which is cheapest will depend on what times you are travelling, and whether suitable advances are available or not. Note that option 1 would require your return journey to be on a train that calls at Coventry.
If you are making another trip from Manchester to London before this trip, another option might be to buy two return tickets for this first trip (one return Manchester to London, and another London to Manchester), using the outward portions for that trip, and the return portions for the trip where you are breaking journey at Coventry. By using the return portion of a ticket for your Manchester to London trip, this would allow you to break journey at Coventry overnight.
Your journey is further complicated by there being alternative routes from Manchester to London, some via Coventry and some not. So for the outward leg you would need tickets valid via Coventry, while for the return journey you may not want to tie yourself to tickets that require you to take the slow route via Coventry. As previous posters have said, you can use this forum's ticketing site to find tickets that are valid by both routes, as it allows you to specify different via points for the outward and return journeys.
But when breaking journey, be careful of any restrictions on the ticket, such as restrictions on the departure times from Manchester or arrival times into London. If you are intending to travel down to London straight after your meeting in Coventry, you might regret buying a ticket that does not allow arrival into Euston between 16:00 and 19:30, for example.
Also, when breaking journey, especially overnight, I would always recommend buying a traditional card ticket. With e tickets, attempting to use the same ticket again on a different day can be problematic. Unfortunately this forum's ticketing site only appears to issue e tickets if you specify Euston or London Terminals as the destination.
With this kind of journey with alternative routes, looking at tickets to/from a common point (such as Rugby in this case, as suggested previously), can also throw up useful savings.
In summary, while you might think your journey not particularly strange, it is not a typical journey. There are a number of possible options for doing it, which is why journey planners don't give a simple answer. Added to which, as spending the night in Coventry may be significantly cheaper than spending the night in London, it might be worth spending slightly more on tickets if that allows you to spend significantly less on accommodation. No journey planner is going to answer that for you!
easyken
19 May 2011
Manchester
Apologies - spending the night in London. In Coventry for 3/4 hours at a conference, then heading down to the smoke.
