London Thameslink terminals and breaking journeys
Mrdini
20 Sep 2011
Maybe I'm being a bit dim or missing something but... If I buy an off-peak day return from south of London to "London Thameslink", the ticket is marked as "Break of journey allowed". Does that mean that I can break my journey at e.g. London Bridge then continue onwards to Farringdon?
NRE at https://www.nationalrail.co.uk/travel-information/travelling-in-london/ says "You are not allowed to break your journey on the cross-London leg on London Underground, Elizabeth line or DLR services." so by dint of omission, I assume I am allowed to break my journey if travelling on Thameslink?
Or can I only break my journey at stations that are not London Thameslink stations - and once I exit at a London Thameslink station, that ticket is considered used?
Thanks!
Yes. Although in practical terms, if you use a paper ticket there is a good chance it would be (wrongly) retained by the barrier, so I would suggest speaking to the gateline staff to ask to keep the ticket. With an eTicket it may reject it when you attempt to recommence your journey after breaking it.
Breaking your journey at a station within your destination station group is valid but not something that barriers are generally programmed to consider, in essence.
This is specifically about the cross-London journey that is permitted by the Maltese cross (or dagger) symbol on a ticket from one side of London to another. Tickets to London Thameslink don't fall into this category as they do not have a Maltese cross/dagger, they are simply valid on National Rail services to any of the stations in the London Thameslink group.
You can break your journey when using Thameslink on a cross-London transfer since there is nothing in the NRCoT that excludes this - unlike with Underground, Elizabeth line and DLR services. Again, it is probably not intended for this to be the case or a particularly foreseen use-case, so you may have some difficulty at the barriers.
You can break your journey at any station along a permitted route, which includes intermediate stations in the London Thameslink group before reaching the final station in the group (i.e. St Pancras coming from the south).
jfollows
26 Feb 2011
Wilmslow
Perfect, thanks! Surprised how hard it is to find this information
National Rail Conditions of Travel
Haywain
3 Feb 2013
I rarely use the break of journey option but London Thameslink tickets do not seem to be retained by barriers, so this isn't a problem.
Note that you in this case you can only continue north as far as City Thameslink; "London Thameslink" only includes Farringdon from the north. The maps halfway down https://www.nationalrail.co.uk/travel-information/travelling-in-london/ show this if you look at them carefully, but as the blurb admits, "The below diagrams may help"!
You are incorrect; London Thameslink includes - as the name suggests - all of the stations from London Bridge to St Pancras, whether you are coming in from the north or the south.
London Terminals tickets aren't valid to travel to Farringdon in either direction. From the north they are valid as far as St Pancras, from the south as far as City Thameslink.
SAPhil
27 Jan 2011
They don't, however, work the barriers when you try to get back in! On the odd occasion I've done this I've had to find someone to let me in.
Ralph Ayres
2 May 2012
West London
Correct. Sorry, half asleep.
