Line inspection train
Trains1
7 Aug 2024
Manchester
Hello all
I seem to recall seeing a yellow train with 2 locos in Hale (Manchester) back in summer 2021. I can't remember if it had Network Rail on the side. But my question being how often does a Network Rail inspection train get sent down a line like the Mid-Cheshire line?
Thanks
Freightmaster
Verified Rep
7 Jul 2009
Hello all
Thanks
The PLPR (Plain Line Pattern Recognition) trains, which tend to mostly run during the daytime, cover lines on a four-weekly basis (the mid-Cheshire line was visited on September 22nd, for example)
There are also UTU (Ultrasonic Testing Unit) trains, which tend to mostly run overnight,
and cover lines more sporadically on a 2/3/6 month rolling cycle.
MARK
Trains1
7 Aug 2024
Manchester
cover lines on a four-weekly basis (the mid-Cheshire line was visited on September 22nd for example)
There are also UTU (Ultrasonic testing Unit) trains, which tend to mostly run overnight,
MARK
Thank you.
Is there an easy way to see when they last visited a line apart from trawling through rtt? And what class locos are used 37?
Freightmaster
Verified Rep
7 Jul 2009
Thank you.
Yes - I have full daily/weekly/monthly diagrams and loco allocations on my website! ;)
But as per my previous reply, the last run was September 22nd, so the next train will be on October 19th, the following on November 17th, and so on, so as soon as you notice a PLPR train running, just add 28 days to work out when it will run again...
On that particular diagram, yes.
Most other PLPR workings use HST power cars, as does the NMT (New Measurement Train)
MARK
stuving
26 Jan 2017
Since these trains run in timetabled paths, they must be included in the timetable planning process. They are, and are listed in the national section of the Timetable Planing Rules. (You can also get there on the NR website via Home>Industry and commercial>Information for operators>Operational Rules.)
This list is not easy to understand. It's also frozen; any changes after its publication date won't be in it. The timing of these documents is not obvious, partly because timetable planning is a long, slow, process (even if these Network Services paths get fixed first and are pretty stable). The validity is from "Subsidiary Timetable Change 2025" which is May 2025, there does not appear to be a new version for each Principal (December) change date.
Trains1
7 Aug 2024
Manchester
MARK
Thank you!
Do they ever send the 43 down the Mid-Cheshire line?
Thank you
Freightmaster
Verified Rep
7 Jul 2009
Thank you!
That's one of the only two PLPR diagrams that is not 43-hauled (the other being the East Anglian 1Q9x workings)
But the (43-hauled) NMT visits Stockport and traverses the WCML past Acton Bridge several times a month,
so there are plenty of opportunities to see the 43s in action if you are prepared to venture a little distance
away from the mid-Cheshire line. There are also 43-hauled workings which pass Chester (on the way to/from
Holyhead) and Wrexham.
MARK
Freightmaster
Verified Rep
7 Jul 2009
That one is booked for a pair of class 73s (962+963)
The daytime, 37-hauled train actually runs tomorrow afternoon(my estimate was a day out!):
...and is booked to be worked by 37610+667
MARK
