Large stations - slow speeds. Where fastest?
hexagon789
2 Sep 2016
All lines are 25mph to Coke Ovens then 55mph then the new crossover there is 40mph, 35mph through Oulton Broad North station. 60mph from then on.
Does that affect journey times much or does the better acceleration of the 755s negate the speed changes?
dk1
2 Oct 2009
East Anglia
It’s actually better & 1 minute was removed from most schedules. No need for the painful check down on the up into Oulton Broad if heading to Norwich. Down road it wasn’t really possible to get above 50mph due to Lowestoft boxes fixed distant.
lammergeier
5 Oct 2017
Really, that doesn't appear to be reflected in the appendix (although I haven't looked at the Instructions section closely). I could understand the limit being accelerate on sight when it's slowing for a hazard or braking distance, but I can't imagine that the complex pointwork at New Street can be traversed much faster than the existing PSR, so it would need the rear of the train clear before it could accelerate.
I believe it was going to be 10 arriving and 15 departing, but with one of the new "A" boards at the end of the platform meaning the train could accelerate to speed as the front of the train passed the sign, not the rear. Useful for Pendos and double Voyagers. It hasn't gone ahead (yet), hence why the SA hasn't been updated, but that doesn't mean it won't at some point.
I remembered departing from Doncaster southbound on my first ever ride on an IEP felt extremely rapid.
Don't remember what platform, but it felt like it took off like a tube train.
trundlewagon
4 Oct 2019
I'm sure it was all set to happen a couple of years ago - I remember someone (a New St driver) mentioning it just before it was supposed to happen and then recall seeing something in the WONs about it being cancelled.
Sly Old Fox
21 Jul 2008
England
Seen many a train hit the platform at Paddington at 30mph at least. ATP and TPWS make sure that nothing untoward occurs.
voyagerdude220
13 Oct 2005
You wouldn’t have been through Carstairs station itself at that speed though. The platform loops are much slower, 20 or 40 mph.
I'm sure that the line speed through Carstairs has always been around 90mph in both directions before the engineering work was completed.
waverley47
17 Apr 2015
Technically yes. In practice, there was a tsr that had been there for several years limiting the up fast to 50 and the down fast to 60 from memory
21 May 2014
I always find the 10mph at Birmingham New Street incredibly difficult to stick to in a 323 on Train Sim World, particularly when approaching the New Street platforms from Five Ways through the tunnel. Makes me realise the skill the drivers must have to be able to do it in real life!
(Or, the sim is wonky...)
TreacleMiller
22 Feb 2020
P4 and P3 southbound are 70mph, onto "Slow" lines which really aren't that slow! It's faster than departing onto fast lines due to points speeds.
I don't think they'll be many places faster than that.
merry
19 Oct 2011
uk
I’m sure we’re all been told: “there’s no such thing as an approach controlled signal”.
Yes, and it is the correct thing to assume. A signal means exactly the aspect displayed, and nothing more until it changes. Because it very well might not step up, and that quote is made to remind drivers.
Tell the (surviving) driver at the Colwich collision (or countless others)...
Efini92
14 Dec 2016
You should never assume anything.
43066
24 Nov 2019
Well thanks for the reminder. It’s not like I’ve spent years driving trains managing to cope with simultaneously knowing what a red signal means, and also knowing what an approach control signal is.
Anyone who has to resort to lying to deliver training really shouldn’t be training at all. It says something worrying about the state of learning and development in this industry - something that elsewhere it taken very seriously.
D6975
26 Nov 2009
Bristol
Penzance is 15 out of the platforms, but once you've cleared the pointwork it's straight up to 70. Notable as there's not an awful lot of 60+ west of Plymouth and what there is is all in very short sections.
45Fox
17 May 2022
Leicester
Leicester is 40 mph for passenger trains through platform 2, both directions, and platform 3 in the up direction. Interestingly down services approaching platform 3 from the south are 15 mph max, signalling overlaps at the north end I understand.
plugwash
29 May 2015
In fact, you can increase capacity if you can speed up the conflicting moves.
I suspect the problem is you often end up in a "robbing peter to pay paul" situation. To increase the speeds means longer stopping distances, larger radius pointwork and so-on. So you increase the speed of movement through the conflict zone but also increase it's length.
Northampton
Yes, and also often you end up only being able to speed up some moves by slowing others. A difficult balancing act.
That may be true (the recent Kings Cross remodelling is an example) but not always. The York and Newcastle ones I mentioned earlier pretty much fitted within the original lengths (at Newcastle they didn't have much option!) but replaced a large number of slow turnouts with fewer and faster ones. This probably got rid of some parallel routes, but that was offset by the trains taking less time to pass over the routes that remained. As I suggested earlier, the net effect may be positive or negative for capacity, but it should be a benefit for journey time.
Dren Ahmeti
17 Oct 2017
Reading
Fastest route through Reading is 95mph on the Up/Down Main, I think.
I would not call Taunton large in the context of what this thread is really asking for. It's very similar size and significance to Stevenage, which has 125mph through the platforms.
Yep, Reading P9 is 80/HST95, and P10 is 85/HST95, rising to 125 on both sides.
bahnause
30 Dec 2016
bülach (switzerland)
I set the speed to what I want it to be and leave it to the train to do the heavy lifting :D. Thy want us to drive "on the dot" in slow and busy locations. It is the slow speeds you lose the most time at.
The very flat braking curves with ETCS L1 LS is causing and will cause a lot of trouble over here...
Railcar
27 Nov 2017
When leaving the terminal platforms at London Bridge, 377 drivers on the metro services seem to ease out at slow speed until the whole of the train is clear of the throat and then they accelerate to line speed through Bermondsey, especially if they are going to pick up the Down Sussex Fast outside New Cross Gate (examples- the Epsom semi-fasts and the 'Cats and Tats'.)
