lookapigeon
- Joined
- 18 Dec 2009
- Messages
- 184
I would second the option to get an refurbished/former corporate laptop. Cosmetically it maybe a bit worn, but you'll get more bang for the buck. It would enable you to get a better spec machine, 8GB maybe fine for the occasional single-tasking web browsing, but these days 16GB should be the minimum, as software tends to get bulkier over time and if there is a situation whereby you may find yourself doing several things at once with a load of softwares open the machine will start to creak with 8GB.
An alternative opinion on this is just keeping using Windows 10 if it works for you.
Yes, it maybe unsupported after October 2025 however, if you are careful and do not visit dodgy sites, opening unsolicited emails attachments, run antivirus with its updates, are behind a firewall etc the risk is marginal. It won't suddenly die in October 2025. It also appears that Microsoft in its keen-ness to foist Windows 11 onto everone has forgotten about quality control and also the UI experience is badly designed, they have fiddled with too much.
