Isolating Rail on a DC Layout
Masbroughlad
2 Mar 2011
Midlands
If I have an isolating rail on a DC layout, how does it work?
Could I use it on a station siding to uncouple a locomotive from its stock, run it forwards a couple of cms and isolate it? Then I could couple a loco on the other end and move off.
Is that how it works? What would I need? Is it an isolating straight and an on-off or an on-on switch, please?
Do I just connect it to the back of the power transformer?
Cowley
15 Apr 2016
Devon
That’s exactly right.
What you need is a plastic fishplate (which Peco do) and if it’s a dead end siding you’ll only need one. You then solder a lead either side of it and run them under the board to an inline switch so that you can isolate it or make it live again.
Class15
30 Dec 2021
North London or Mildmay line
I have a ready to go one of these, without doing anything myself. I don’t know where you can find them now though.
4COR
30 Jan 2019
W Oxon (UWL exile)
The switch? Pretty much any single pole on-off will do it (under the assumption there are no other odd feeds coming onto the rail where the loco will it). A SPST (single pole, single throw) is ideal, and indeed an SPDT (single.pole, double throw) will also be fine - just leave one of the outputs disconnected.
You could use something like a Hornby one, but they are way too expensive for what they are.
If the track plan is.more than a single dead end siding, then posting the plan will help!
