Historical Signalling Question, Morecambe Promenade, 1960s/1970s?
Chrius56000
18 Aug 2010
Walsall
. . .I have a copy of the I R.S.E.'s booklet on "Route Indicators", and in it the recommendation was given:–
. . ."In general, if consideration is given to equipping a signal with a multiple–lamp route indicator then it is strongly recommended to also renew the associated signal in colour–light form".
. . .This was done at Heysham Harbour when the three –platform modernised station was brought into use in 1970, but for some strange reason Morecambe Promenade was not modernised likewise – the last home signal admitting trains to the platforms remained as a semaphore with a "calling–on" arm underneath, with a multiple–lamp platform indicator right up to closure and resiting of the station by Railtrack in 1994!
. . .Can anyone suggest why Morecambe Promenade's Home signal was not modernised in colour–light form to the I.R.S.E. recommendation when the route indicator was added?
TheHovisKid
9 Sep 2008
Heysham
Wasn't there powers for a curve leading Heysham-Bare, but not acted on? Local lore said there was, but then local lore....
Might have been on hold pending that, if there was?
John Webb
5 Jun 2010
St Albans
An IRSE recommendation is purely that, not a standard that the railways are compelled to follow, even if it is a 'strong recommendation'!
I don't know the history of the two stations you mention, but if Haysham Harbour was a complete rebuild in 1970 with changes to track layout, then it probably required resignalling anyway.
Morecombe's Home signal may previously had a mechanical indicator which, due to wear and tear, needed replacing. So the simple choice of a multi-lamp indicator was a quick-fix and cheaper than replacing the whole signal, perhaps?
MarkyT
20 May 2012
Torbay
Very likely. Here's the signal box diagram:
and a view along the frame:
Points look all mechanical in which case much of the detection may have been mechanical. That would all need converting to electric detection if a colour light was to be substituted. The platforms seem to be without track-circuits. TCs would usually be provided for colour light conversion. Far too much work to do all that for a box with limited life. Mechanical indicators have been replaced elsewhere with electrical ones. Shrewsbury and Worcester areas have some I think.
Acathater
11 Dec 2025
NorthWest
Just a guess, but why spend money on a minor update like that when the whole station fabric was falling apart?
But more importantly in 1970 there was still a lot of redundant trackwork around there relating to the old abandoned Euston Rd and Northumberland St stations. Getting rid would presumably have needed signalling changes on a larger scale than just a route indicator.
MarkyT
20 May 2012
Torbay
. . . Unfortunately the signal and point numbers, T.C. numbers, etc., on that diagram of Morecambe Signal Box are all to blurry/furry for me to read I'm afraid!
Very blurry, I agree. I think the Home main arm is lever #54. That fits in with the sequence from previous signal #53 coming from Bare Lane. The call-on might be 23, or 25. I deduced no TCs in the platform by the solid black colouring and lack of round track circuit indicator lamps. Facing points all seem to have 2 numbers adjacent to them, so that implies separate facing point lock levers. The black levers in the frame picture are all full-height, indicating mechanical operation rather than electric or pneumatic point machines.
TheHovisKid
9 Sep 2008
Heysham
Some of the trackwork away from the platforms got a little reprieve during the Britannia Bridge replacement.
Belperpete
17 Aug 2018
Also, the content of the IRSE booklets were basically the opinion of the author of each particular booklet, not official IRSE policy.
CN12
14 Apr 2019
The main home signal was No:54 with a calling on arm No:55. In 1986 there was a 4 way theatre type route indicator, 1 to platform 1 etc. There was a ground signal No:56 which was to all sidings.
