GBRF class 66 re-gearing
HJ10001
3 Dec 2024
According to WNXX "While the DBC /6 program has stalled for evaluation with ten locomotives modified, it is understood that GBRf are looking at re-gearing several standard geared Class 66s to/6 spec. As GBRf already four /6 spec Class 66s, 66793-66796 (all allocated to the GBHH pool) now with additional re-geared Class 66s on the horizon, renumbering these four may be feasible as they are currently locked in the number range with standard Class 66s - 66693-66696 perhaps?"
XCTurbostar
13 Sep 2014
The post referenced is paywalled;
Summarised
It is understood that GBRf are looking at re-gearing several standard Class 66s to /6 spec. GBRf already has four /6 spec Class 66s (66793-66796 all allocated to the GBHH pool) but these could be renumbered.
wickham
3 Feb 2021
Knaphill
I'm unable to access the source, does it confirm which locos will be re-geared or how many?
It does not quote how many, just states "some": But don't forget that 66793-796 are allready 66/6 geared, although you would not know it from the numbers.
43096
23 Nov 2015
But the GBHH pool code does give it away.
Rail Quest
8 Apr 2023
Warrington
First renumber on TOPS of the GB variety...66689 has appeared, which appears to be the ex 66779 as that seems to have disappeared
Moving this one here to continue the discussion.
I wonder what number range is going to be used, based on this. Does that mean 66680-689 or 689-699? It would also be interesting to see if 793-796 get renumbered.
D365
29 Jun 2012
Any indication of whether GBRf will, like DBC, be using regeared 66s to replace 60s? Or is this simply because GBRf has an abundance of 75mph freight locomotives with most of the 69s and imported 66s now in traffic.
Class15
30 Dec 2021
North London or Mildmay line
Possibly what’s happening is that the 99s will begin replacing 66s on container trains (is it August they’re supposed to enter service?) and free up 66s for use on heavier trains for which 66/6s are more suitable? Obviously might be completely wrong but that’s my guess.
ac6000cw
10 May 2014
Cambridge, UK
There's some info on what traffic the 99s *might* be used on in the recent posts in the class 99 thread - https://www.railforums.co.uk/threads/gbrf-class-99-30-locomotives-now-ordered.228787/post-7222967 . According an article in the April Modern Railways the first two are due in the UK in June, and ''A main line debut is likely to be around September or October"
Class15
30 Dec 2021
I’ve seen that (in fact I replied on the relevant thread) but my gut is still that they will largely be for container trains.
Wyrleybart
29 Mar 2020
South Staffordshire
My gut is telling me the 99s will be "pathfinding" for at least the first twelve months, gradually enabling GBRf Ops to get a feel of how these beasts perform. In my view GBRf are a very progressive company so John Smith andhis team will be wanting to squeeze every single pound of investment out of them. I don't really think it will happen, but neither would I be surprised if GBRf were to do some kind of a deal with ROG to use a 93 as basic familiarity electric loco for base training of a phalanx of non AC electric GBRf drivers to get some basic experience on the Stadler product. Although they are mechanically different, I wonder how much commonality there is between the driving cab of the 93 and the 99.
XCTurbostar
13 Sep 2014
Image shows 66779 now 66689 at Longport
D365
29 Jun 2012
To follow on from the earlier discussion. I think that Evening Star being regeared/renumbered makes it all the more interesting for its future preservation. An example of freight flows evolving with time and locomotives being modified accordingly to suit.
trainmania100
8 Nov 2015
Newhaven
Can't say I've seen many double headed GBRf trains, what's the point of this if I'm not being so daft, given GBRf locos already seem to be coping fine?
Wyrleybart
29 Mar 2020
South Staffordshire
John Smith, being an ex BR Trainload Freight senior has always said the profit is in the last wagon of the train, so if a 66/6 is hauling more wagons than a 66/0, then the train is either more profitable, or less loss making.
ac6000cw
10 May 2014
Cambridge, UK
Exactly - hauling longer/heavier trains using the same amount of crew and track capacity (= cost) is what's driven the development of freight motive power for the last 200 years, from Locomotion to class 59 (as 59001 and 59005 are the UK 'heaviest train' joint record holders). The basic business economics of running a railway, really.
