French sleeper train route query
enginedin
15 Dec 2020
I'm investigating whether I can get from Chamonix to Paris using a sleeper service. I don't mind if it's a slightly convoluted route.
The most likely sleeper service to user looks to the the Briançon one, for which the last stop looks like it's Crest (does it not stop in Lyon?) - is there a sensible way to get from Bellegarde to Crest?
The main reason I'd like to do this is just time efficiency and be able to get an early-ish Eurostar. The alternative looks like getting the last day train which gets into Paris at 23:42; doing the whole journey in 1 day leaving Chamonix (very) early doesn't really get me back in the UK early enough for prearranged plans.
Are there any other possible routes I've not thought of?
Mike99
4 Mar 2011
G E M L
Have a look in DB Bahn, it lists various connections from Bellegarde(Ain) to Crest which may be suitable. The last train only connections depart at Bellegarde at14:00 arrive Crest 18:29.
ABB125
23 Jul 2016
University of Birmingham
The Grenoble to Veynes Devoluy line is quite scenic (albeit not quick!) and you can change there (or at Gap) onto the Briancon sleeper. However it depends on your risk appetite as to how early you plan to arrive at Veynes...
Chamonix to Grenoble is easy, if you're already at Bellegarde you can gat one of the BB22200 hauled TER services through Chambery.
mad_rich
12 Feb 2013
Newcastle
Is this for summer or winter? If it's summer, you might take a look at the European Sleeper Milan-Brussels service, which will call somewhere in Switzerland. Bern, I think. The timetable's not finalised yet.
You also have the Travelski Express (winter only), from Bourg-St-Maurice, which you might pick up at Moutiers? Still a long journey though.
Having done Chamonix a few times, my preferred route is bus to Geneva, then TGV to Paris.
rvdborgt
24 Feb 2022
Leuven
Somewhere near Bern, I assume. I don't think they'll be turning the train around.
30907
By which time you could be in Paris anyway :(
iknowyeah
11 Aug 2016
It doesn't need to reverse, there's an alternative route from Thun to Bern that approaches from the correct direction for Basel, I can see it from my bedroom window
30907
Via Belp. Is it suitable operationally?
iknowyeah
11 Aug 2016
Not in the day due to volume of traffic but at the times a sleeper will pass through I don't see why not, I don't think it closes for maintenance, I often see loco and operational moves in the dead of night
