Fare Advice Please Macclesfield to Retford
Stuwhu
4 Mar 2010
Stoke
Hello,
Please could anyone help me with the cheapest way to get from Macc to Retford on Saturday 17th April. Want to get to Retford about 12 and leave again about 6. Doesn't matter about route, just would like it cheap.
Thank you for any help
Stuu
A Macclesfield (MAC) to Retford (RET) Off Peak Return (SVR) is £30.80.
You can split the journey up to make it cheaper by buying a combination of tickets, especially for a day ticket as Off Peak Day (CDR) fares are cheaper than SVR fares. I recommend the Avantix Traveller NFM05 program for this as it's easier than using ticket booking sites.
MAC-SPT CDR £4.20 (Virgin Trains Only) or £5.50 (Any Permitted)
SPT-RET SVR £22.10
Total = £26.30
Not a great saving but I reckon alternative splits can bring this down.
I looked at splitting again at Sheffield but this was more expensive than a Sheffield-Retford, due to no CDR being available between Sheffield & Retford (only SDR).
You may be able to save money by buying a Stockport - Doncaster advance ticket on TPE, and then going via the ECML to Retford. This used to be very infrequent but it is much better now thanks to Hull Trains (DON - RET SDR is £8.30 which can be bought on board). If you have a 16-25 railcard then advance fares are half price so this is more likely to be cheaper for a holder of such a railcard. This only works if you can tie yourself to a specific train. I doubt the saving will be worth it though due to the loss of flexibility in case of delays or a change of travel plans. The TPE booking site is here http://www.buytickets.tpexpress.co.uk/
ashworth
10 Sep 2008
Notts
Splitting at Kiveton Park saves you slightly more.
Macclesfield to Kiveton Park (via Stockport) - £18.60 (Off Peak Return)
Kiveton Park to Retford - £7 (Anytime Day Return)
Total £25.60
This only requires changes of train at Stockport and Sheffield
All trains between Shefield and Retford call at Kiveton Park and so splitting there is not a problem.
Ah yes there is a 'fares boundary' (if you can call it that?) around Kiveton Park. It makes for some rather interesting ticketing to either side of the boundary from certain places. Rather like Fisketon and Rolleston. It'd be good to live between those two (less than a mile apart!) and pick and choose based on the cheapest fares!
Under BR these differences either did not exist or were negligible but privitisation has certainly changed that. And it's only going to get worse...!
