I will not apologise again for my writing capabilities. I had redeemed 255 points for the said free journey and then 252/3 points left. I have used about four other redeemed tickets previously.
considering that this thread has turned into the spanish inquisition and therefore a witch hunt, I have been reluctant to answer a so called simple question. Though I have put the facts, to the best of my recollection. Have you considered that i may have writing disabilities? Which also highly likely to be exacerbated by lack of sleep.
Difficulties with writing, including that which is caused by disability, can certainly lead to confusion being created where none was intended. But neither that, nor a lack of sleep, is a valid reason for refusing to answer questions on a thread that you have started yourself in order to receive advice.
To put it as simply as I can, because of the things that you are constantly referring to that aren't related to the core issues here, I am confused as to what you want. No one can give you meaningful advice if you don't co-operate be providing the information that's needed. Lack of a phone signal, unfamiliarity with a phone, a dislike of using ATM's, a lack of sleep, difficulties in writing and a number of other irrelevant matter shave been introduced, seemingly as a way of avoiding the central problem, which is that you made a conscious decision to board a train without a valid ticket and you have not paid the UPFN's that you were issued.
Whatever reasons you have for coming to that decision doesn't matter. You have outstanding debts that will influence the position that you are in as a result of your poor decision. Do you want assistance in dealing with whatever position that is, or not?
If you do, then that's what this thread needs to focus on. If not, that's your prerogative but it's pointless continuing with any discussion if that's the case. If the thread stays open you'll only feel more aggrieved at the questioning unless or until you provide some answers.
