Experiment - swap 16-17 and 16-25 railcards in drop down lists
Egg Centric
6 Oct 2018
Land of the Prince Bishops
There are lots of cases of people who select 16-17 railcard when they "mean" 16-25 railcard. Very few indeed the other way around.
Cynics will note that 16-17 railcard gives a better discount and terms.
Non cynics however will note that the 16-17 railcard is usually "first in the list" on any "select a railcard" drop down when buying a ticket. So to the extent that there is genuine confusion, it would promote selecting the 16-17.
I propose therefore that retailers could agree to put the 16-25 railcard first, rather than 16-17 railcard, for a few months. And we see to what extent, if at all, the confusion now goes "the other way".
Bertie the bus
15 Aug 2014
Similarly, I propose moving Wembley Stadium station to somewhere in Buckinghamshire to see whether those confused people who accidently purchase Wembley Stadium – Marylebone tickets start buying ones for the journey they have made.
Kite159
27 Jan 2014
West of Andover
Or adjust the 16-25 Railcard so it's a 18-25 Railcard.
Or even get rid of the 16-17 Saver and allow 16+17 year olds child rate tickets.
N1
10 Aug 2022
Or be even more sensible and just have an 18-30 Railcard.
As is done to varying levels in some places already. Translink yLink gives 50% off for 17-23 year olds, and Scotland NEC gives half off seasons, but only a third of singles and returns. Both are free.
As a easy to implement thing changing the order might make a small impact with no real negatives against.
Trainbike46
18 Sep 2021
belfast
It'd be a good idea to swap them around, it makes truly accidental mis-selection less likely, and when it does happen it would be in the way that doesn't risk prosecution.
That would be sensible. I always thought it was an odd choice to have a separate 26-30 railcard with slightly different conditions, it seems unnecessarily complex to me.
With removal of the July / August concession?
The July/August concession being that the minimum fare before 10am rule doesn't exist in those months?
As the logic for having the 10am rule doesn't really apply in July or August, I'd suggest retaining it for both. For most passengers, the difference has to be pretty limited though!
kkong
8 Sep 2008
That would disadvantage some young passengers who currently use the 16-25 Railcard on ScotRail (and, to a much lesser extent, Caledonian Sleeper), where the 16-17 Saver isn't valid.
N1
10 Aug 2022
It would. Again, in a sensible world Scot Government would allow 16-17 saver to be used on Scotrail and Sleeper, and make the Young Scot NEC card discount the same as 16-17 saver (not quite as generous now).
kkong
8 Sep 2008
I believe the 16-17 Saver isn't accepted because it is a type of "railcard" (importantly, with a higher percentage discount than other railcards) which was introduced after ScotGov became responsible for Scottish railway finances.
I assume they didn't reach a financial settlement to their liking with ATOC/RDG or whoever else, hence it not being accepted.
