Dragging a dead HST?
green howards
18 Jun 2013
If a locomotive is dragging a dead HST using the draw bar under the end cover can it do so without any restrictions?
Is there a speed restriction (apart from the hauling locomotive's)?
Can an HST in service be hauled with passengers on?
marks87
23 Jun 2010
Dundee
There's a video on YouTube of a 91 dragging an in-service HST at high speed.
Mugby
25 Nov 2012
Derby
I remember being on Derby station one saturday night many years ago (in BR days) when a Cross Country HST came in from the north. There must have been a problem with the rear power car at some point so it had been removed and the rear coach had been locked off and a tail lamp mounted.
It was the one and only time I've ever seen that done and I wondered how they coped with turning it round at it's destination!
richw
10 Jun 2010
Liskeard
would of connected a loco up at terminal most probably
hairyhandedfool
14 Apr 2008
....It was the one and only time I've ever seen that done and I wondered how they coped with turning it round at it's destination!
Can't have been many terminus stations for it to go to on a cross country working, so it's possible that it simply drove on to whichever depot was to look after it for the night.
Another incident at Derby many years ago when a HST arrived from Birmingham direction being pushed by another one. Several blokes with big hammers then spent quite a long time before they could disconnect the emergency coupling bar, during which time the second HST was stopped across the junction and blocking any other arrivals including my train home.
shedman
14 Feb 2011
The 0710 Leeds - Aberdeen used to be a good bet to run with a single power car and starting at York back in the days of GNER, I know as I've prepped and departed it!
E&W Lucas
21 Jan 2010
The instruction is that the speed is limited to the speed of the lowest vehicle in the formation, which in reality, is likely to be the assisting loco.
The theoretical maximum is 110. There are no control jumpers on the front of a HST, therefore only the brake control unit on the assisting loco will be operative. 110 is the maximum in that situation.
Operators may have written a lower figure into their contingency plans, since the BR manuals were written. I've never dragged one, with anything permitted to run at over 100.
Yes, routinely.
Geezah1984
1 Feb 2011
There was an interesting video on YouTube from Network Rail showing how to use a 67 on thunderbird duties and I am sure it used a HST for one segment. I can sadly not find it now though :(
D6975
26 Nov 2009
Bristol
Used to happen quite often when XC HSTs were common through Bristol.
One dead power car meant you were'nt allowed over the Devon banks without assistance. As Bristol was the last place en route likely to have a spare loco, it was usually attached here, seen it done many times.
