Double deckers on HS2
Mgameing123
29 Apr 2023
Denmark
Hi guys, I just realised that since HS2 is going to be built using European loading gauge, doesn’t that mean we could run double decker trains on HS2?
AM9
13 May 2014
St Albans
Yes we could, but there would be no value in a marginal increase in route capacity which would prevent level boarding and requir modification to all station platforms along the line
Average passenger journey times would also increase by a small amount.
MatthewHutton
17 Aug 2024
Oxford
Also seems unlikely that even if HS2 is extended to Crewe that it won’t use the legacy tracks after that.
Perhaps maybe also the Picc-Vic tunnel will be done.
Double decker stock doesn’t necessarily preclude level boarding.
The original plan was two batches of trains, the first batch (already ordered) to current uk gauge so they can continue off the line to Manchester, Glasgow etc.
Then a second batch for once the line was completed to Manchester which would be high capacity trains, probably double deck, which would take over the core services, freeing the others for more destinations eg the then proposed Eastern branch with services to Yorkshire etc
There was recently a question of using double deck TGV style trains on the Channel tunnel services, there is currently a compliance question of level boarding, ramps and lifts due to the 300mm above rail lower floor height, vs 550mm or 760mm standard platform heights. Link is quite a detailed article with diagrams and photos to explain it (probably needs to be viewed on big screen by those with sight issues)
7 Jan 2009
Alstom have done great things with their Double Deck TGVs but do bear in mind that even 'Continental' loading gauge has limitations: yes, you can comfortably stand up on both decks but they are still somewhat cramped and the toilets particularly so. The incremental seat numbers do come up at a cost.
The various Swiss double deck trains are probably the most comfortable to travel in and have wide doors and reasonably good level boarding. Their seat capacity is only marginally higher than those of an IEP in practice (although the door/saloon entry widths into the C800s are very constrained and lead to slower boarding than SBB manage).
Obviously, where HS2 trains run 'off-route', eg. to anywhere in the NW and Scotland Double Decks are non-runners.
If the Continental loading gauge was about 25cm larger in both width and height that would have been brilliant (see eg Finland!)
Mgameing123
29 Apr 2023
Denmark
The IEP also has TERRIBLE seats that are crammed together meanwhile the Swiss might be focusing more on comfort so that can explain quite a bit.
stuu
2 Sep 2011
They have terrible seats but they are absolutely not crammed together, they have more legroom in airline seats than anything else I'm aware of (GWR ones anyway, never been on any of the other variants)
Northampton
AIUI the HS2 platforms will not be UIC gauge compliant in either height or distance from the rail to provide level boarding with UK gauge ("classic-compatible") trains. So double-deckers would still face a lower deck width restriction.
stuu
2 Sep 2011
I would hope they have had the sense to design them so they can be easily adjusted later, with gap fillers fitted to platforms for classic compatible stock
Northampton
Given the likelihood of captive HS2 stock ever running now, I don't think it'd make too much difference.
NCT
18 Apr 2025
Aren't the HS2 full height platforms just 760mm EU-standard platforms 'extruded upwards'? Lower sector gauge clearance shouldn't be an issue surely?
Yew
12 Mar 2011
Isn't this a problem that has already been solved, for the Class3 373 with their folding steps?
fandroid
9 Nov 2014
Hampshire
If they turn up on Cross Channel services my guess is that the British public will love them. My family's top deck travel last year from Paris to Geneva was brilliant.
Mgameing123
29 Apr 2023
Denmark
I'd love to ride a double decker between London & Manchester (whenever Phase 2 actually happens)
