Disruption around Scunthorpe 24/05/26
SomeTrainboy
30 Aug 2024
NE Lincs
Not sure where else to put this but does anyone know what's happening at Scunthorpe? I've looked on Traksy and the signaller has put STOP in the signal berth and is holding 1B51 at Barnetby.
And 1B93 should've left Scunthorpe an hour and a half ago?
SomeTrainboy
30 Aug 2024
NE Lincs
Keadby swing bridge has failed.
Typical, they spent time fixing it only for it to fail a week later!
Makes you wonder how effective it would be to allow TPE services via Brigg, and have them change ends at Doncaster, won't be the best but would keep it running.
D6130
12 Jan 2021
West Yorkshire/Tuscany
I suspect that the problem may have been caused by rapid expansion of one or more of the bridge components due to the sudden onset of very hot weather.
Dr Hoo
10 Nov 2015
Hope Valley
Is the Brigg line, with its multiple signal boxes, even ‘open’ on a Sunday?
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
That's probably right. Either the bridge won't quite reach the position where the locks can engage, or they do engage but not far enough for the limit switches that detect that the bridge is in the right place and locked to operate. Having commissioned a few swing and lifting bridges in my time, that's the kind of problem that happens. (Solved by the foreman of the Scherzer lift bridge at Waterford many years ago by getting a few lads from the pub to jump up and down on the end - not really on for a railway swing bridge, though)
