Class 90 fails to load
16 Jan 2014
Hi all,
I have just downloaded the class 90 and DVT pack, from the Armstrong Powerhouse website and also downloaded the extra stock files etc, but it fails to load the scenario when it loads the route is there but there is no stock.
Also when I load the class 90 to play in Quick drive mode, it fails to load at all just saying " an error occurred trying to load this Quick Drive Scenario", the only class 90 that works is the separate class 90 add on when I bought the GEML route
Any Ideas please chaps
Thanks
Darandio
24 Feb 2007
You say you downloaded everything, but are you sure?
Mk3 extra stock?
43367
16 Jan 2014
Rightio after a bit more messing about I seem to have all the files, but its seems its just the virgin coaches that im having bother with, the ones from the pretendolino, and I have downloaded them and I can choose them on the Quick Drive mode, but they just don't show up, and when I put them in a consist the DVT and 90 loads just not the coaches, they just stay see through.
Any ideas, they seem to have been saved under the Keith Moss, WCML North folder.
Any ideas chaps???
Domh245
6 Apr 2013
nowhere
That would be because the reskin uses the mk3 carriages from the original WCML (Glasgow-Carlisle)
43367
16 Jan 2014
But I already have the WCML north, the one with Carlisle Glasgow carstairs etc, and the class 325's work fine on that route, or is it a diferent version.
I got it from the train sim store as WCML North
Domh245
6 Apr 2013
nowhere
Have you enabled the WCMLN content in the scenario - in the filter fly out box in the right, under keithmross? That *should* fix it
43367
16 Jan 2014
How do you do that please??, I'm sorry I'm quite a novice on here
Domh245
6 Apr 2013
nowhere
When you load up the scenario editor, in the middle of the left hand side, there is a list of all the assets that can be placed in the scenario. When you click on the little blue cube with an orange arrow on it, a flyout appears on the middle right of the window. On this flyout, at the top is a drop down menu. From this menu, right at the bottom is an option called "keithmross" and when you click on this, the list of content developed by Mr Ross is shown. From this you need to click the middle box of the row "WCMLN", which should tick the end box as well. This should enable the content that came with WCMLN, which you can check by going under the locomotive menu in the asset box and finding the class 86 options. Don't worry about being a novice, everyone is a novice at some point
43367
16 Jan 2014
I cant see the Keith Moss option, the Pretendolino DVT has loaded and can be driven ok, but the coaches are there in a way, I mean I can load them into a consist but just cant see them when it comes to driving them, the 90 and DVT are there then just a blank space where the coaches should be, like I said the train can be driven ok, just cant see the coaches grrrrrr.
Its the same with my class 91 into East Coast grey reskin too,
