Class 700 reliability
ctrh136
2 Sep 2014
Hi all,
I'm not sure if there is a similar thread here but I've had a look through the last month or so but haven't seen one.
I've noticed that Thameslink seem to be cancelling quite a few services due to "more trains than usual needing repairs at the same time" - this seems to have been going on for a while as I remember seeing this when they often cancelled the (at the time) one a day train to/from East Grinstead. Is this because the class 700s are proving unreliable as I can't believe that operations now are more intensive than pre-Covid? Or am I missing something?
hooverboy
12 Oct 2017
Hi all,
The class 700 are mechanically very reliable.When they run,(more often than not the cause of cancellation is crew-related),they are robust and punctual.
The main quirk with these units is the aesthetics and the interior,not the stuff that makes it go.
gm671
3 Oct 2015
Current issue is many units are out of mileage and Siemens are struggling to get them through periodic exams on time. Not been told if this is down to lack of labour, parts or both.
ctrh136
2 Sep 2014
Ah that makes sense.
I've seen that TL have temporarily withdrawn the Littlehampton service (which is transferring to Southern in May anyway) and have withdrawn one East Grinstead peak service (which is being covered by Southern to/from London Bridge) until early May.
Dave91131
13 Jun 2018
700111 appears to have been out of use at Peterborough for about a fortnight now, unsure if mechanical / maintenance related though.
Javelin_55
9 Apr 2020
South East
Apparently the wheel lathe at Hornsey is out of service so units are stacking up waiting for Three Bridges which doesn't help.
700111 hasn't run in passenger service for nearly a month, due to suspension issues.
Failed Unit
26 Jan 2009
Central Belt
It is interesting on this contract I believe it is a "no train - no pay". But I bet Siemens are glad the full Thameslink service was never implemented. I notice at WGC the Sevenoaks service is frequently step up to save a unit.
The one that arrives at 0712 for example would normally form the 0802. It is not going back out at 0732 to save a unit. 387s are more common as well (not that anyone will complain at that.)
