This is a question regarding the visual design, not the inside of the cabs. When the 458s and 460s were rebuilt, they received a new cab design which featured 'wings' of sorts on the sides. Do these serve any purpose or are they just for looks?
The 458s had them from when they were built.This is a question regarding the visual design, not the inside of the cabs. When the 458s and 460s were rebuilt, they received a new cab design which featured 'wings' of sorts on the sides. Do these serve any purpose or are they just for looks?
The change was only really at the lower part of the front corners, the forward extension at the corners was reduced in size at the bottom third or so, the lighting units were also changed and moved outwards. But about the top half of the ex 458, around the outer side of the windows, is the same as it always was. The 460 though had removable GRP fairings and their usually hidden cab fronts needed significant changes to match the ex 458 units.This is a question regarding the visual design, not the inside of the cabs. When the 458s and 460s were rebuilt, they received a new cab design which featured 'wings' of sorts on the sides. Do these serve any purpose or are they just for looks?
totally this. The new gangway flexitors needed the space.the lighting units were also changed and moved outwards.
Ah, so that‘s what they’re called!…The new gangway flexitors needed the space.
Certainly some were, as these needed to be injected in to service (as 5 cars) before any of the /0's could be taken out of service and sent North for the rebuild.As far as I know, the ex-460s were dealt with first,
I'm not sure if I've understood this correctly, but would I be right in assuming that the side extensions/wings were not removed because they were structurally integral to the body, rather than it being an intentional design choice?460 DM conversion almost complete on the left. 458 being stripped at conversion on the right.
