Class 231: engines
Tom williams
2 Jan 2018
Hi all,
I was train spotting in Newport today, and saw a few class 231's running through. Was just wondering what brand of diesel engine they had? Was also wondering how many cylinders they have.
Thanks.
Tom.
ac6000cw
10 May 2014
Cambridge, UK
AFAIK - they have four 645hp/480kW Deutz V8, 16-litre diesel engines in the power car (same as the 755/4 units)
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Bit of overkill power wise? How does the fuel consumption compare to other units e.g. 172 or 195?
Energy
29 Dec 2018
Presumably its better for fuel economy and maintanence to have bigger engines but you don't need to run them at 100%?
ac6000cw
10 May 2014
Cambridge, UK
From what was said on the 755 thread in the past, my understanding is the FLIRTS run as many engines as are needed for power at the time. They have electric traction, and each diesel 'genset' contributes power to a common power bus within the unit, and the control system balances out the engine hours across all four engines.
The upcoming class 756 FLIRTS for TfW will be tri-mode (OHLE/battery/diesel) so the centre 'power pack' car - I assume - will have a mixture of batteries and diesel engines installed (the electric traction equipment is installed in the other cars, with just the bogies nearest the cabs motored).
I was slightly surprised that the 231's were not built as diesel-battery hybrids, to allow energy recovery during braking etc. - but maybe that was deemed too expensive or not available as an option at the time (versus the delivery schedule)?
randyrippley
21 Feb 2016
How tight is the spacing for the engines? Having a vee-engine mounted underfloor seems counterintuitive.
anamyd
17 Aug 2018
It's been done before in other train types (such as the 80x units that are fitted with V12 MTUs underfloor).
