Rail Ranger
- Joined
- 20 Feb 2014
- Messages
- 1,151
The campaigning wheels are already in motion at Ashley and Plumley and have been for some time.
That's interesting Rail Ranger do you have a source for that?They've said that they are going to build the platform in such a way that it could be moved to accommodate the reinstatement of the second track.
I agree with this, with the slight amendment of turning Mobberly into a bit of a national rail/metrolink interchange. The journey times from the Northwich stations to Manchester are too long IMO already without the new Cheadle stop. Probably off topic I suppose. A new general thread about what should be done around the line is probably in order.If Network Rail are serious about doing anything with the Mid Cheshire Line then a new Cheadle station would be down my list of priorities. Doing the Mobberley-Airport connection would be my first port of call, then electrification. I’d convert the old Ashley-Stockport section to Metrolink.
comments:
A desire for the proposals to be more ambitious (16 comments) in terms of passive provision for a second line / platform and encouraging active travel
report response:
The scope of this project is to allow for passenger services to stop on the Mid-Cheshire line at Cheadle under the current service pattern, which is just one train per hour. Work is ongoing outside of this project to look at the future demand and capacity along this line. The project will not prohibit the introduction of a second line and platform in future if they are required.
Yes Deansgate Junction to Edgeley Junction, Stockport was freight only until the Mid Cheshire Line service was diverted that way in May 1989. Previously the service ran via Sale to Manchester Oxford Road. Sharston Junction to Cheadle Village Junction (through Cheadle) was singled in the early 1970s so that two new underbridges for the new motorway (then the M63) would only have to accommodate a single line.I actually currently commute to Cheadle sometimes using the Mid Cheshire line so would be one of the people who'd benefit massively from a new station there, but doing this before any work is done on the surrounding infrastructure to support it is a massive red flag to me. If I remember correctly, the Nav Road to Stockport section was freight only for a while (is anyone able to confirm that?), presumably explaining the single track section. Not rectifying that bottleneck before placing a new station on top of it feels like it's asking for trouble. The Mid Cheshire line sees relatively good reliability compared to the surrounding lines but the single track bottlenecks, both there and at Nav Rd are what seem to cause the most issues.
AI says whatever! Does it have reliable sources?Thanks Baxenden. AI says "The platform for the new Cheadle railway station is being designed so that it can be "trimmed back" or adjusted to safeguard the space should a double track ever be reinstated along that section of the line".
The proposed single platform to serve the proposed railway station would be sited on the Northern side of the existing Chester to Manchester railway line, would consist of a modular platform design of lightweight construction and would include covered waiting shelters for passengers.
Without having seen the site, the “obvious” solution is to build a permanent platform (with all fixtures, fittings and associated services) to serve the currently non-existent second track then “bolt” some pre-fab modular platform in front of it, that is robust enough to be a permanent solution, but which can be removed without having to do anything to the “real” platform other than install new tactiles and paint a new yellow line.Thanks for the responses. Wonder how they intend to trim back the platform, not heard of that engineering technique before!
