Buying RENFE tickets
1 Jan 2013
Any advice on purchasing tickets in Spain? I want to travel from Benidorm to Cordoba then Cordoba to Sevilla the next day and on to Granada the next day returning to Benidorm the day after.
I've tried the multi ticket on www.renfe.com but it seems unable to sell for a journey with changes.. all very confusing :(
eddp
5 Aug 2011
Berlin
You can buy tickets with a change, it's possible it won't come up straight away but if you click on "con Transbordo" then it'll show you those tickets. However, this only works for one change, if your journey needs more than one change then in my experience you normally need to book more than one ticket. If you get the message "
Para el trayecto de IDA no existe conexion directa o este tren no circula en la fecha solicitada, si lo desea puede consultar el mismo trayecto con transbordo", that's to check journeys with a change.
One thing to bear in mind is that Benidorm is only served by rail by FGV (Ferrocarrils de la Generalitat Valenciana, the regional government's train service) and so the RENFE ticket you'll need to buy is from Alicante. You'll then need to buy a separate ticket from Benidorm to Alicante on FGV (or by bus).
I think it's also a lot easier (and quicker) to travel via Madrid to get from Granada to Alicante/Benidorm, as otherwise the journey by rail would take you via Alcazar de San Juan and Xativa (changing at both). The journey via Madrid is high speed from Antequera to Madrid and then from Madrid to Alicante, and the departure and arrival are both at Puerta de Atocha. The only connection I can find via the Alcazar de San Juan route used a sleeper to Albacete or Valencia (arriving in the early hours of the morning) and then onwards to Alicante from there.
Hope this is of some use!
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
The website is one fo the more difficult to use and requires patience and perseverance. The last time I tried it our trip was cancelled due to illness, so I never actually got as far as buying a ticket, but I did plenty of research on how to travel from Madrid to various other cities.
I'm sure you'll get there in the end. Good luck!
richardderby
20 Nov 2010
quote You'll then need to buy a separate ticket from Benidorm to Alicante on FGV
your Renfe ticket includes complementary onwards travel on local rail networks to connect to (or from) your destination (including the Benidorm tram from Alicante). you are issued a ticket with a six letter code, which when inputted into the local train/ tram ticket machine, issues you a free onwards journey pass. takes some getting used to, but good to know... :)
ianhr
17 Sep 2013
For passengers over 60 it is also worth buying a "Tarjeta Dorada" which gives substantial but variable discounts on virtually all RENFE services ( but not FEVE, although I am not sure what has happened since RENFE took over FEVE). Last year it only cost 5 euros, is valid for one year, and you do not have to be a Spanish national, just show your passport as proof of age at any RENFE ticket office.
You can get one from the RENFE office in London for €10, just by submitting your passport details.
They issue it as an e-ticket which you print at home. http://www.spanish-rail.co.uk/
That gets round the need to visit a RENFE station in Spain to buy a Tarjeta Dorada, so you can buy tickets* in advance and print them at home before setting out.
Note that the discounts are applied to standard fares, not the cheap advances (Promo). However it's still a very good deal.
I found that the 40% discounted fares for regional trains (Media Distanca) do not come up until later in the booking process than for high-speed trains.
And the free suburban ticket does not apply to MD fares.
*you have to insert the Tarjeta Dorada number during the booking process
