Busiest Level Crossing?
jopsuk
13 May 2008
PaulLothian- as it is a controlled crossing, the keeper shouldn't (I think I'm right in saying) close the second half of the barrier and clear the signal until everything is off- including pedestrians.
I've heard Helpston used to split into two crossings, with cars able to wait in the "refuge" area?
Hydro
5 Mar 2007
Mount Pleasant crossing in Soton has to come quite high in the list. The barriers are down not just frequently, but for fairly long periods too. I've seen the barriers go up, wait a few seconds, then the sequence starts again. More often than not it's to let more than one train across.
PaulLothian
27 Sep 2010
Linlithgow
That would also make sense of the longer periods between barriers closing and train arriving, I guess. I walked across (reasonably briskly), and I would reckon that I took over 45 seconds. Could have doubled that time if pushing grandson in his buggy.
jopsuk
13 May 2008
The long time is also a function of being a fast line. Ideally they want the barriers closed early enough to give the trains green signals all the way.
dk1
2 Oct 2009
East Anglia
Exactly! Trains should be signalled on greens whenever possible. Road traffic will just have to wait. All the crawling peg to peg or distant 'on' will make it wait even longer & that doesnt help emergency services waiting either.
devon_metro
11 Oct 2005
At a rough guess there are ~16tph passing over, excluding any ECS movements.
GNER 91128
13 Jan 2011
Peterborough
There's the manned crossing a couple of hundred metres further down the line on Woodcroft Rd and they may hold people in the middle "safe bit" Although I'm not too sure as it's not a main road and don't have much cause to use it.
Tomnick
10 Jun 2005
I doubt anyone would be allowed to remain between the GNR and Midland lines at Woodcroft - there's no gates to prevent them wandering onto the 125mph Down Fast...and why would you want to keep someone there when you could just get them across all five lines without too much delay?
