Brockley Whins-Tyne Dock Reinstatement
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
Yes, and not just welcome news for the operators of the Port but also assisting the overall availability of capacity on the ECML between Northallerton-Durham-Newcastle-South Shields.
turbo mick
17 Aug 2005
reading
plus south of sunderland from ryhope grange SB to billingham has been re signalled so there is plenty of room for extra traffic along the durham coast
HST Power
25 Nov 2010
Quite suprising it has cost £1.6m for such a short piece of track.
Then they'd better make sure it's idiot proof because railway theft is on the rise (apparently).
If they want to do something useful to the T&W Metro, they can introduce non-stopping services.
142094
7 Nov 2009
Newcastle
Might have the new fibre optic type cables which are worthless for scrap. Then again might not be.
142094
7 Nov 2009
Newcastle
Wonder how they have installed them - would have been better to bury them straight away, but probably used concrete trunking. So that means even if the cables are worthless, some sod will still cause disruption to get at them.
142094
7 Nov 2009
Newcastle
On the Durham Coast line they've buried the cables VERY deep.
Seaton Carew area was notorious for cable thefts a few years back. Seems like it has shifted the problem tomwards Middlesbrough, been delayed a few times in Eaglescliffe area due to cable thefts in recent months.
HST Power
25 Nov 2010
Anyone found to be stealing cables should be shot on the spot! :lol:
Bit of a more extreme opinion, but oh well, it's almost Friday!
Sir_Clagalot
9 Aug 2007
it's all very well banging on about fibre optic cabling, but the signals have to get their power from somewhere, and for the time being it's good old copper cable that supplies it.
With new signal heads being of the LED type then surely a solar panel and small wind turbine charging some hi-tech batteries inside the pole, with a system that on lightly used lines the signal heads can be switched off at night to save power.
PinzaC55
6 Sep 2010
They'd nick the hi-tech batteries and the wind turbine and solar panel. We're not talking here about people with scruples.
PinzaC55
6 Sep 2010
That's interesting stuff. I couldn't help noticing that they say reopening the Leamside Line would bring significant benefits but that it's infrastructure has "deteriorated".....and their reaction is to put off thinking about it till 2015! When, of course, it will have deteriorated even more. :(
cawky22
7 Aug 2009
yes it is very interesting report.
Does anyone know how often the new east curve is being used ?
Buttsy
20 May 2011
Hanborough
That's one of the serious disbenefits of the Metro. While it had the advantage (for me) of reopening part of my local line (Sunderland to Penshaw) it limits the possibilities of "proper" train services at Sunderland and blocks any possibility of the Durham Coast line being electrified.
Would it not be possible to have dual voltage overhead stock for the different currents used as the Eurostar has. Switchovers could take place in Heworth & Sunderland stations or be done automatically by computer in a netural section prior to the stations? I appreciate that this would push up the cost of the stock, but the technology must be available...
PinzaC55
6 Sep 2010
It would be technically possible I suppose but it would mean that all electric stock would need to be fitted with dual voltage and since the Metro is 1500 DC as opposed to 25000 AC the cost would be mind boggling.
Although it would be possible to run diesel services over the Hylton line it would still cause problems of congestion at Sunderland station which the chumps who run the railways have rebuilt with only two platforms.
jonty14
3 Aug 2009
Rottweil Germany
Hi ReverendFozz.
Of topic I know but I have just seen you are from Murton. I live in Germany but I was raised up in Dalton-le-Dale. Out of interest when did the Durham coast line loose all its signalboxes? I was shocked that they all had gone when I was last home.
Jon
PinzaC55
6 Sep 2010
Blackhall Rocks went in about 1984, Easington and Horden in the 1990's. The rest (except for Seaham) went last October, thought Cemetery North had been destroyed by arson about a year before.
turbo mick
17 Aug 2005
reading
Hi ReverendFozz.
Jon
Ryhope grange box controls most of the durham coast route now i think
mick
safc for ever
BOSCH
18 Oct 2007
Ryhope,as well as having its own signals also controls all the way to hartlepool,including Church street crossing,Greatham still has its own signals as does Billingham,Norton On Tees and Norton South,Norton East is closed(but does open on very rare occasions.
The signals between Ryhope/Hartlepool have the prefix NS on the plate which stands for Northallerton to Sunderland. ;)
