Booked Traction
ValleyLines142
25 Jul 2011
Gloucester
It's booked for a 153+150 and upon departure at Bristol at 1721, it is very busy. If it's a single 150, I wish you the very best!! :lol:
PHILIPE
14 Nov 2011
Caerphilly
The 150/1s and 150/2s have their own diagrams but frequently criss cross.
The class quoted on Realtimetrains is NOT what is diagrammed but what the train is timed for. A train could be diagrammed for Class 158 (90mph) but required to be timed at 75mph max to enable it to be worked by 150.
SprinterMan
20 Sep 2010
Hertford
I know, a good example of that is the old WAG, 1W91 1510 Swansea to Chester. Timed for a Sprinter but booked for a 175/0. Thanks for all the info.
Adam :D
SprinterMan
20 Sep 2010
Hertford
Booked to be a 221 (5-car)
Excellent, thanks very much. At least if there is a breakdown on another train, they won't steal a set to substitute for it, which is what happened last time I was on a train booked for an 9 car Voyager formation. Do you know how busy this train will be roughly? Also is 221141 used in a common pool with the 220s?
Adam :D
ValleyLines142
25 Jul 2011
Gloucester
It's hard to tell exactly how busy it will be, but it is a Saturday afternoon on a Voyager which means one thing: overcrowding!! As long as you reserve a seat for the journey, I think you'll be okay.
Normally yes, although it can in reality turn up on anything.
There ARE separate Diagrams. Have you seen them at all ? But, as I have said, they work each others all the time in practice.
Well I've never seen any consistency in the 150 diagrams with FGW, except for probably the 0600 Penzance to Cardiff, which is always almosta 150/1.
As far as I can see, except for the above, if I was catching a service operated by a 150, I couldn't even hazard a guess as to whether it'd be a 150/1 or 150/2. In fairness, I don't think FGW care, as long as the service runs!
louis97
14 May 2008
Derby
Adam :D
Not really sure how busy it will be. Tends not to be that busy in Devon, however not done it up the line.
Yes 221141 is used in a common pool with the 220s.
