Banbury Depot
BanburyBlue
18 May 2015
I just saw on a FB group a picture of some form of building work at the Banbury Depot site. Does this mean that Banbury Depot is finally going to arrive?
What do you mean? It was never built to the full spec because of changes in HS2 construction timelines. Chiltern won't be able to access Aylesbury depot via Princes Risborough as there is a big blockade due so it will be off the back of that.
BanburyBlue
18 May 2015
Here you go….
I never realised that was why the depot was never finished. It seemed like 1 minute it was going to be there, next minute not. There was never a published reason.
BanburyBlue
18 May 2015
So why does the Princes Risborough to Aylesbury line blockade stop Banbury depot being built?
As I said above, there was a change in the timeline for HS2 construction so the depot didn't need to be built so soon (or as big). The is a two month blockade of the Princes Risborough line in spring 2023 which means trains cannot get to Aylesbury depot, hence the works at Banbury taking place now.
2192
16 Aug 2020
Derby UK
Is the route to Aylesbury depot via Rickmansworth blocked at the same time, or just too long a detour?
