Arriva Merseyside & North West 2026 onwards
gka472l
29 Apr 2016
Merseyside
Seems there's no dedicated thread about the above fleets (or at least one in the last few years), so as Arriva Merseyside will be massively effected by the upcoming Liverpool City Region bus franchising, probably worth having this thread to discuss developments & news in these fleets.
St Helens franchising starts on 6/9/26 with Stagecoach replacing Arriva, having won the franchise for this area.
Likely to be mass vehicle moves on 5/9/26, with most, if not all the E400's currently at St Helens, going to Speke to replace older deckers (get the 61 plate Wright deckers in while you can!). Pulsars 12 plate & newer to go to other depots, 61 plate and older likely for disposal, as nothing older than 2012 should be in the Arriva Merseyside/NW fleet by the end of the year. Unknown what the Optare Solo's are doing, possibly some to Wales?
Wirral franchising starts 25/10/26 with Go North West replacing Arriva, having won the franchise for this area
Like St Helens, mass vehicle movements likely on 24/10/26, Streetlites to Southport, 'METRO' E200MMC's to Runcorn. 20 of the B5LH's are to be converted to full diesel and used as driver trainers in Arriva generally (NW, NE, Yorkshire & London all getting some so I hear), first one (4851) already out of service for this....
HTH
W176 XMA
7 Jul 2024
My house
Asked this on the other thread but probably more relevant here, where are Southports E200 MMCs going when replaced by Streetlites?
Simon75
25 May 2016
Runcorn is not part of the franchise, so i guess that will be the only garage left
gka472l
29 Apr 2016
Merseyside
Probably nowhere until the Sefton franchise starts. They're all standard Arriva inside so could end up anywhere and in blue, as LCR is ordering all the vehicles by the looks of it.
Statto
8 Feb 2011
At home or at the pub
Arriva have 40 Pulsars at Runcorn, 8 are on 14 plate, 4 on 12 plate, the rest 61 plate & older, that are going need replacing, i know the Birkenhead E200MMCs are replacing some of the Pulsars, but that won't be enough to replace everything.
markymark2000
11 May 2015
Great Britain
On the other thread (link and quote below) they mention that Streetlites are supposedly off to Southport to replace the E200MMCs that would suggest those E200MMCs could also move to Runcorn. That gives 34 buses between both the Southport and Birkenhead 200MMCs. That's to replace 40 pulsars. Depending on moving about any other buses, the 8 14 plate Pulsars could move to Southport too to release more Metro 200MMCs to Runcorn. Purely speculative though and just my thoughts on what could happen.
(https://www.railforums.co.uk/thread...n-bus-franchising.282426/page-22#post-7864998)
The Streetlites are transferring to Southport to replace their YX17 E200MMC batch.
W176 XMA
7 Jul 2024
My house
It was mentioned the YX17 ones were leaving and being replaced by Streetlites but I understand how plans always change
Statto
8 Feb 2011
I'm not sure about Arriva's plans for interworking the 360 with the X30 when the 360 moves to Runcorn is a good idea.
I was on the X30 yesterday (11.03 from Warrington to Chester) the M56 westbound was gridlocked with a lot of the traffic migrating to the A56 through Preston Brook as an alternative, making the A56 & surrounding roads gridlocked as well, then add in congestion on the Hoole Road, that the X30 i was on arrived at Chester 40 minutes late at 13.06 (should have arrived at 12.26). The return from Chester (which should have departed 12.31) was about 40 late throughout too & arrived in Warrington at 14.37 instead of 13.59.
It then struck me anytime the M56 goes belly up between Runcorn & the M53, traffic then migrates causing chaos to the A56 (& nearby roads) thus causes havoc with reliability to the X30, which will make things fun when the X30 interworks with the 360.
markymark2000
11 May 2015
Great Britain
The 360 is the exact same when anything happens on the M6/M62. All traffic diverts via Warrington Town Centre and the 360 gets stuck in the traffic then. I think it will be a disaster waiting to happen if the X30/360 plan is tried. I only hope that Arriva sees sense and changes the plan.
That said, I'm not sure how long the 360 will last anyway long term with the 612 running half hourly from Newton Le Willows to Wigan, unless there is a very strong flow to/from Warrington, or Arriva has some very loyal passengers, then I struggle to see how the 360 will be sustainable after September.
Budge1980
31 Jul 2024
Haddenham
Now that Bus Times is settling down after the St Helen's transfer, I was wondering what is the status of the Hydrogens that were all too briefly used on the 10 and 10A back in June 2024. Fleet numbers 4900-4909. Is it right they still show as part of the Arriva Merseyside fleet and are they stored at another Arriva Merseyside garage?
TheGrandWazoo
18 Feb 2013
Aren't they the property of the combined authority (rather than Arriva) and slated for conversion to EVs?
Statto
8 Feb 2011
Looking at bustimes.org the 329 & 360 still interwork with each other rather than the planed 329 interworking with 110, & 360 interworking with X30.
gka472l
29 Apr 2016
Merseyside
First of the E400's from Rhyl have seemingly transferred to Speke, 4537/8, although not in service yet.
darylyates17
8 Nov 2015
St Helens
Is there a possibility all the Gemini 2 Hybrids could end up at Laird Street in there final couple of weeks since it looks like they will be withdrawn once LS goes to Go Ahead.
gka472l
29 Apr 2016
Merseyside
Who knows.....but 4492/5 have transferred to Birkenhead this week, with just 4855/6/9-61/3/4 remaining at Speke
childwallblues
3 Jul 2014
Liverpool, UK
Rhyl has received many of its new E400s and some of those that they have replaced have been stored at Laird Street on their way to new homes/scrapyard. These include 4489 which had a varied career being new to Macclefield (with 4490/91) for route 38 to Crewe. Moved to Winsford when Macclesfield closed then on to Speke were it spent many years before ending up at Rhyl.
joieman
18 Feb 2024
Loughborough
I've heard Arriva Midlands' Wright Streetdeck/Newpower EV Conversion 8600 (6764 MW) is on loan from Leicester to Liverpool?
gka472l
29 Apr 2016
Merseyside
I believe something from Leicester is on loan, as well as Arriva's E400EV AR74ZEB....presumably in connection with the Labour conference in Liverpool next week....
childwallblues
3 Jul 2014
Liverpool, UK
4408 has been re-registered back to CX58EZV and transferred to Green Lane to replace 4841 whilst its accident damage is repaired. 4408 was seen. in service on route 27 yesterday
