1R76 - Failed points outside Stoke Tunnel (15/02)
jfowkes
20 Jul 2017
Hi all,
I'm on 1R76 , EMR Norwich to Derby. We've had a points failure south of Stoke Tunnel and currently reversing down the East Coast Mainline slow lines, presumably back to the Tallington Crossovers where we can rejoin the mainline and head north again.
I'm just curious, the reversal is very slow with frequent brake applications and stops. I'm presuming this is safety related? The line isn't bi-di signalled here, so the train movement has to be more carefully controlled?
Luckily I don't have a connection to make so I can take it easy on here. Would be more interesting in daylight though!
24 Oct 2015
Hi all,
I'm on 1R76 , EMR Norwich to Derby. We've had a points failure south of Stoke Tunnel and currently reversing down the WCML slow lines, presumably back to the Tallington Crossovers where we can rejoin the mainline and head north again.
I'm just curious, the reversal is very slow with frequent brake applications and stops. I'm presuming this is safety related? The line isn't bi-di signalled here so the train movement has to be more carefully controlled?
There will be a set mandatory speed for doing an unsignnalled reverse move.
jfowkes
20 Jul 2017
Is this basically because in the absence of signals, there are no position references for the driver?
EDIT: actually thinking about it they can still see signals on the other lines so that can't be the only reason.
24 Oct 2015
Yes if there is no signals to obey then speed is a factor. Signals on all other lines are totally irrelevant.
starlight73
1 May 2024
maybe AWS related? Someone will be along to correct me soon haha!
dk1
2 Oct 2009
East Anglia
We're terminating short at Nottingham, I assume for crew related reasons...
Possibly yes. Conductor issues maybe so a driver will take it ECS to Etches Park if need be.
Wouldn't be AWS. That would just get cancelled each time as agreed with signaller.
isn't it the case that level crossings have to be taken slower in reverse?
Only if they have wrong direction controls. Everything else would be as per signallers instructiono.
jfowkes
20 Jul 2017
We strike northward!
Train crew and control sound like they're doing a good job of arranging onward travel for those that need it.
pdeaves
14 Sep 2014
Gateway to the South West
I think the person to whom you were replying meant that seeing the other ('normal') signals could still help the driver recognise where they are, rather than those signals giving an indication that must be obeyed. If there's a steep gradient approaching signal X normally, there is high chance there is a steep gradient on the next line across in the same place. That kind of thing.
jfowkes
20 Jul 2017
Yeah I meant just for "route knowledge" reasons.
Andy Pacer
11 Jul 2017
Leicestershire
Or more likely Eastcroft.
EDIT - In fact forget that, I see it is meant to run throughout to Derby! Didn't realise any did that.
dk1
2 Oct 2009
East Anglia
Never mind the poor passengers wanting to get home and paying, not being paid, to be on that train.
Unlike the "poor traincrew".
Alright, them too then.
Fair enough. Wasn’t sure if some regional units went on to Etches Park.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Slight tangent from the main discussion however, if I recall correctly, the 170 fleet home depot is DY Etches Park, and 158s at NM Eastcroft. Both end up crossing over between the two of course.
They do, I jumped the gun as the Norwich services don't usually serve Derby and therefore generally associate with Etches Park.
Alongside the Derby direct service, there is the odd evening service which terminates at Sheffield before forming a 1Cxx Derby service from there. I believe this is seen in reverse in the morning with the unit ex-Etches forming a 1Fxx to Sheffield before working to Norwich.
